Re: In the middle of a tie rod job need advice ASAP (Honkin'Max)
Shoot everthing with a rust penetrant.
Using a punch and hammer smack the nut toward the "tighten" direction then toward "loosen".
Using a pry bar or equivalent apply pressure to the tie rod near the end to cause tension on the joint. While doing this and using your third hand with a perfect-fit wrench on the nut turn either way to get the nut loose then remove.
Repeat as needed.
George Dill
Repeat as needed.
George Dill
