Re: IMIV Video (Oscar1)
Below is an excerpt from the iMIV Owners Manual, but in short you need to go to
http://www.imiv.ca --> Downloads --> VWIM and flash the file in the same way firmware would be uploaded. Hopefully that helps, if you have any other questions do not hesitate to ask.
Where To Get The Video While In Motion Feature
A special file has to be downloaded from
http://www.imiv.ca (log-in necessary). In order to download that file you have to agree to the terms of use and type in your iMIVs serial number, which can be found in 2 different spots:
1. Underneath the bar code on the iMIV unit itself
2. On the iPod screen after putting the iPod into Service Mode
It is important to download the file especially for your device, because the file is being created on request with the serial number you entered and will not work on other devices.
How To Install Video While In Motion
After downloading and unpacking the archive from our website you will see a *.wav file. This file has to be installed just in the same way as you upload a new firmware version to your device. See 3.2.2.1 (about how to put the adapter into Service Mode) and 3.2.2.2 (about how to upload a new firmware to the iMIV) for detailed information about the upload process.
