XM Install Update
HELP
Next to dip switch on the side of the iMIV is an LED light. Should that be on when there is power going to the iMIV?
Prior to attempting to install an XM radio my iMIV was working. In doing the install of the XM, I tapped into the iMIV power and ground wires (green for ground and the red with black stripe for power).
Now, neither the iMIV or the XM work. The LED on the iMIV does not on. Volt meter reading into the iMIV plug is "0".
I have pulled the taps and soldered all the connections but still the iMIV and XM do not work and show no sighs of power on the volt meter.
I hate to pull the HU again...too hard to get back in.
Should I run another switched power line from the fuse panel on the drivers side? Any recommendations for which fuses are switched?
All is not well in the land of
Oz
Modified by Ozzie at 8:15 AM 5-4-2009
HELP
Oz
