Quick question, i'm thinking about getting the new iMIV LE for my S60. However, their website asks if my car is MELBUS equipped? My car is an '08 which i think came with satellite radio prep? is this the MELBUS cable? Thanks!
Re: iMIV LE ipod integration (iggy637)
Yes. In the rear. If you want your ipod up front you'll need a shorter cable or have to run a long imiv-ipod cable back to the front.
is it a hard install to do? how long would you guess on average?
Re: (iggy637)
If you have the Sat prep cable then it is about the easiest DIY install ever. It should take less then 20 minutes.
Basically you'll need to:
1. mount the unit (ahesive velcro is great for this).
2. attach sat prep cable to unit
3. attach ipod cable to unit and run wire to destination for ipod (this is the time consuming part)
4. attach power cable to fuse panel using an add-a-circuit
click the weblink in my signature for pictures of how to remove panels and do the wiring.
Re: (ss60)
Quote, originally posted by ss60 »
Time consuming only if the ipod is not stashed in the rear near the iMIV.
