Ignition Coil Harness Replacement
4.3K views 4 replies 5 participants last post by  Gigatech707
My coil pack wiring is getting to the point where I need to do something. As most of you guys probably experience the wire insulation is brittle and causing misfires here and there. Any luck finding repair kits off eBay or splicing in good used ones?
#4 is the coil connector, 9494800. This is probably a bare connector, no pig tail included. You will need to order 4 wires also for each connector. Use this wire 30656688. The other one is gold for SRS and 2nd one is a bigger wire. 1mm or 2.5 mm is the OD of the plastic covering.
There's a guy in the UK that sells a replacement harness, if you're not up doing it yourself.
owns 2007 Volvo V70 2.5T
