My idle speed is dropping rather low after sustained running at a higher rpm. For example coming to a stop at a red light after a highway run the motor wants to run at a stalling rpm for a few seconds before restoring a proper idle rpm. Is ther a sensor or idle control motor that I should be watching? Does it have to get worse first? Thanks a million for any input.
Re: Idle controller slow to react (mr magoo)
What M-Y year car, 98, 99 or 2000?
Re: Idle controller slow to react (JRL)
Its a 99 S70. 2.5, normal asp. 115,000, tuned in March with 105K service (incl timing belt/filters/fluids. Sorry about the omission.
Could be the MAF sensor OR most likely is that the ETM is starting to go bad.<br>(Under 200K mile warranty, the ETM).<br>If not one of those it could be one of 10 other things but those two are the most likely to fail
