1 - 6 of 6 Posts
· Registered
2006 S40 T5 AWD M66, 180k miles and going strong
I was replacing my splash shield and noticed a bolt missing. I'm embarrassed to say that I'm just not sure what to search to locate it. I good at going through parts fiche but I just can't locate the right parts diagram.
Here is a picture of the missing bolt when I have the splash guard lowered (looking under the front of the car towards the RHD driver side/center. I am not sure if this is an air hose, cooling hose, or something else. When I search those parts I don't see the metal pipe listed. Could you point me in the right direction? Which part is the metal pipe, or the part the the pipe is bolted into? Any help would be appreciated so I can search and find the matching bolt! Thank you!
Automotive tire Motor vehicle Bumper Automotive exterior Gas
· Registered
2007 S40 2.4i / 2007 C70 T5
That's the charge pipe (from turbo to intercooler). Bolt is M7x16mm and P/N: 982775 according to VIDA.
EDIT: The bolt that holds the intake pipe bracket to the top of the engine is the same P/N. Hopefully you can use it to find one with matching thread pitch.
· Registered
Yes!! Thank you so much for the quick reply. I pretty capable when I have instructions and parts, but if I haven't worked on a part before I just don't know what I'm looking at!
A quick search confirmed exactly what you said.
Part 7 in the diagram, 982775 as you noted
Font Parallel Auto part Diagram Slope
· Registered
That bolt is 7mmX16mm long. Need 3 bolts.
7 Flange screw 1.00 982775 M7x16
Thank you for calling out the 3 bolts! I only saw one missing and after taking a closer look at least 2 are missing. Probably the 3rd too so I'm getting three to replace them all. I don't this this is causing my rattling noise, but it's possible. It didn't make a noise when I hit it with a mallet.
1 - 6 of 6 Posts
