1 - 15 of 15 Posts
Well I was tired of hearing my injectors clicking away at every speed including 80mph on the highway so back on the molding goes. Anyone else get rediculous noise out of their injectors with that rubber crap removed?
I removed the blanket not the molding, but can still hear the injectors clickity clacking away.... drives me nuts but no one else seems to notice....
Re: (imageomega)
ya my blanket is off and thats been fine as I cant hear the injectors over road noise but I was lucky to hear the roar of the wind over the injectors with the rubber off <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0">
Re: (imageomega)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>imageomega</b> »</i></TD></TR><TR><TD CLASS="quote">I removed the blanket not the molding, but can still hear the injectors clickity clacking away.... drives me nuts but no one else seems to notice....</TD></TR></TABLE><p>i removed my blanket the weather strip and installed the evolve hood grill. But its not nosie nore can i here it at 80mph...... and i drive w/o ac all times!!!!! no ac for me!! if i cauld find a smaller belt and rEmove the ac cmpresser i would but im short a belt. any ways... yea so lots of nosies.... are you a tad bit low on oil....? humm maybe yoiu super sonic ears lol
Re: (VolvokidS60R)
ive posted about it before thinking something was up.... not low on oil. Still not 100% sure its the injectors but everything is workin' just fine and theres no other explanation.<p>As I said, others dont seem to notice....
Re: (imageomega)
Can it be your valves?<p>I hear nothing on mine, blanket off, insulation on, at any speed. I can only hear the injectors/valves (not sure which I'm hearing) with the hood up.
Re: (crimnlmnded)
Mine makes quite a racket with them off. But the turbo sounds awesome with it like that. It's getting old though so I'll put both back on before winter.
Re: (llabahn)
With the molding gone, the turbo is a little louder here and I here no injector click. With blanket and molding gone, I hear some tick at low speeds off boost, but at WOT the turbo drowns out the injectors easily, and cruising on the highway, it's completely silent, unless you hammer the gas, and then you still hear only turbo.
Re: (Warpedcow)
Get louder tires <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0"><p>Nick, if you could find a smaller belt, would it work, or would it make some things run backwards? What size do you need?
Re: (AthruC)
I can hear the Under Armour at low speeds too.<p><IMG SRC="http://2.bp.blogspot.com/_aKY2qdGBzoc/RyuCIBQodUI/AAAAAAAAAFY/wBGKSYPeqtg/s400/click.jpg" BORDER="0">
Re: (imageomega)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>imageomega</b> »</i></TD></TR><TR><TD CLASS="quote">ive posted about it before thinking something was up.... not low on oil. Still not 100% sure its the injectors but everything is workin' just fine and theres no other explanation.<p>As I said, others dont seem to notice....</TD></TR></TABLE><br>Kool was just checkin. i mean if im standing out sided my car with it running it makes noise. <br>Adem idk how big of a belt i need to be quite honest. but it would be a good idea....
All Volvos are noisey / valve noise from day one
Discussion Starter · #15 ·
Re: (VolvokidS60R)
just had the oil changed a month ago so it should be fine but the noise was there before and after.
1 - 15 of 15 Posts
