I have a 2001 XC70 and it seems to die without warning. I was driving along and the car just died completely. The only thing that seems to work is the dome light and the radio when I turn the key on. I also hear random clicking in the engine compartment. I check all the fuses and they all have power. But I find if I disconnect the battery for an hour or two and short out the batt terminals it will fire right up. I repeat nothing works including door locks. Any input would be great.
How old is your battery?
I'm with Jim^^^^, check the battery with a carbon pile load tester and inspect your cables VERY well. Bad cables and a bad ground will give you fits.
Helps to post details like mileage and battery newness etc
Battery is nearly new, cables are in great shape and when it is running the alternator is putting the required voltage. The car is a 2001 XC70 with 279,000 km. I have taken off the ground cables and cleaned the contact points. Same as the pos side. When it does die there is plenty of juice in the battery. I just have to leave the car for about an hour with the batt disconnected short the cables to reset and everything comes back to life.
