I just installed B&G springs on my 2002 N/A S60. The springs called for an inch to an inch and a half drop. Since replacing the Springs, Rear shocks, Rear Sway-Bar links, and front struts; My car feels like it has a ton of body roll. It is Extremely loose going throughout turns. Any help would be appreciated!!
Sounds like you may have done something wrong during the install. This is not a common complaint after such an install. What struts and shocks did you install?
Can you take pics of your work? Maybe there will be some visual cues that will reveal an installation error.
Did you have an alignment done after the install? Sounds like bump steer from bad toe angles in the rear.
It sounds like you forgot to install one of your sway bar end links or something.
