1 - 8 of 8 Posts
I bought this lovely very original, NO RUST, 150K mile 240 DL wagon (see classfieds, I think I just sold it an hour ago) but I have to fix a couple of items so if anyone has done these, I would like to know where to start!<p>AC does not blow cold, blower motor seems fine.<br>(I assume I should convert it to R 134a but, in general, what seems to "go" on the AC in these cars)?<br>Fuel gauge is inoperative<br>SRS light is on.<br>Alternator bearing makes a ton of noise, who sells the <U>cheapest one <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> </U>?<p>The other very minor issues I can take care of.<br>Any help would be appreciated, just either IM or email me<br>Thanks<br>JRL
Banned
Re: I could use a little help from any DYI'ers on a 240 (JRL)
I recall a 240 guru on this forum. Not Phil Singer, but the other guy.<p>Try IM-ing him. He was of great help a few years ago when I needed to sort out my GT.
Re: I could use a little help from any DYI'ers on a 240 (TMonk)
'The other guy"??? <IMG NAME="icon" SRC="http://www.vwvortex.com/zeroforum_graphics/screwy.gif" BORDER="0"> <br> I NEVER come here, I know absolutely <U>no one </U>in RWD except for G. Dill
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>TMonk</b> »</i></TD></TR><TR><TD CLASS="quote">I recall a 240 guru on this forum. Not Phil Singer, but the other guy.<p>Try IM-ing him. He was of great help a few years ago when I needed to sort out my GT.</TD></TR></TABLE><p>The "other guy" got banned from the Swedespeed Forums.<p>JRL - I sent you an email.<br>----------------------------------------------------<br>AC does not blow cold, blower motor seems fine. (see below)<br>Fuel gauge is inoperative (see email)<br>SRS light is on.( dump the OBD codes - fix accordingly)<br>Alternator bearing makes a ton of noise (could be just a loose/misaligned belt - look at the mounts for wear)<br>----------------------------------------------------<p>AC won't cool:low/no freon, faulty ac freon pressure switch, loose drive belt, bad electrical wire to AC clutch (check ALL fuses).<p>Post the OBD codes here and we will look up the fixes.<p>George Dill<p>
Banned
Re: I could use a little help from any DYI'ers on a 240 (gdill2)
Hmmm, too bad. He knew his stuff.<p>While I have your guys attention, who's the XC90 guru on SS. Having some minor issues that I need some advice on.
Looking at the XC90 forum...<p><A HREF="http://forums.swedespeed.com/zeroforum?id=27" TARGET="_blank">http://forums.swedespeed.com/zeroforum?id=27</A><p>...looks like this guy knows his stuff...<p><A HREF="http://forums.swedespeed.com/zerouser?cmd=viewprofile&id=20394" TARGET="_blank">http://forums.swedespeed.com/z...20394</A><p>George Dill<p>
This may be a moot point, since the car is apparently sold, but I wouldn't jump too quick to converting to R134 on a 240. I had a 1990 240 wagon a year or so ago and had it refilled with R12, which is still available here in Salisbury. It was around $60/pound, but the conversion kits don't work well, and the R12, being a larger molecule than R134, is less prone to leakage.<p>A/C systems are a pain on the 240s. I'm not looking forward to repairing my 87 under my tight budget.
1 - 8 of 8 Posts
