1 - 9 of 9 Posts
Is this the fuel pump running, anticipating a start? similar to how a fuel pump would run when the key is turned in a car with a traditional ignition switch?
That's the electrical system in the car, nothing to do with fuel.
Could be the HVAC blower running. I've got mine set to continue to run after ignition is shut off to help prevent a stinky A/C duct system.
My Car/Settings/Climate Settings/Recirculation Timer
According to the dealer, it's the car's electrical system turning on, which is what I posted earlier.
But you guys can keep postulating....;)
What DWBF1 said. However, I prefer to think of it as my S60 "purring" after a brief slumber.
I noticed a similar sound as well. I figured it was electrical components... listening with a careful ear, I find it coming from the front drivers side.
Volvo's of the past use to do this, which I thought was a great idea, but no longer, at least in the S60. The recirculation timer only turns off recirculation mode after a certain length of time to prevent fogging or stale air. Kind of a useless feature but I'm glad I can turn that function off.
I've noticed the same sound and tried to find the source. As best I can tell, it's coming from the area of the ABS modulator.
My Land Rover made a similar noise when I opened the door or popped the hood. Again, it was the the same area as the ABS modulator.
I don't think it's the brake system priming/bleeding itself or anything, but something on the nearby firewall leading one to believe that's the case. In any event, it's probably nothing to be alarmed about.
1 - 9 of 9 Posts
