Vibration and humming are two different things, he mentioned humming not vibration.What are you running for tires? The vibration I got from my old lower end tires Nankang NS-II's YUCK
Nonetheless my friend in many cases they work hand in hand.Vibration and humming are two different things, he mentioned humming not vibration.
You mean the center driveshaft that drives the rear wheels? I thought it vibrates the entire car and rain squeals, not hum. I would check the angle gear, has it been inspected lately? Have you done a angle gear fluid change? Is your AWD working? Are you sure it's not coming from the axle bearing for the passenger side driveshaft?Did the same exact thing this weekend. I think I may replace 3 more hubs, one at a time until I figure it out.
Also, won't the rear driveshaft hum really badly if it's out of balance?
I have the same issue, it's not the hub its the tires in my case.
I am running lower end sumitomo tires. I had kumhoe tires before and the noise was there too.. I my tires then were cupped and so I replaced them. But the same sound remained with the new ones. The sound seemed to come more from the front wheel hubs and not the rear. Felt more like drivers side front.What are you running for tires? The vibration I got from my old lower end tires Nankang NS-II's YUCK
Since these brand new tires (few thousand miles ago) I have kept up with my alignment well.. Althought my alignment does go out every oil change or so... normal?I would check tires as well, cupping will cause humming and road noise. IF it is indeed cupped tires, I would would check your alignment.
hhmmm... I did not think about the rear driveshaft... How often does that need to be balanced?Did the same exact thing this weekend. I think I may replace 3 more hubs, one at a time until I figure it out.
what do you recoomend I should do? (to test if it is a seize) btw.. braking is even... no wheel pull in a certain direction.Sounds like brakes rotors caliper seize. bearings failure will change pitch at different speeds, I had my bearings go on my R and dint sound like that.
I didn't have time this past weekend to do both.. I'm hoping to change out the other one in a week and a half.you should have done two sides at once - when i did my rears i though my right was shot, but it was really the left that was really bad
Anything is possible, duder. But after listening to the video it's definitely not that.You mean the center driveshaft that drives the rear wheels? I thought it vibrates the entire car and rain squeals, not hum.
I changed out both rears and what an amazing difference. I went with a set of Beck/Arnley Wheel Bearings and as of now couldn't be happier! Found them on Amazon.com for 90.00 each and the come with all the hardware required.you should have done two sides at once - when i did my rears i though my right was shot, but it was really the left that was really bad
Interesting! I've RARELY seen an inner boot fail like that. Bummer. Messy but easy to fix.![]()
This is why mine is humming. I found it this weekend during a tire change. It is louder while coasting for me.
