1 - 15 of 15 Posts
UPDATE 8/4 - More stuff added
Parting my 98 V70r and have quite a few parts that need to go. Willing to ship, but local pickup in Denver is preferred. All prices do not include shipping.
I will remove stuff as it gets sold.
K24 Turbo. Needs a rebuild. Has the typical wastegate housing crack. Comes with two compressor housings, the v-band housing one and non. $150
131180
131181
131182
Kenne Bell boost a pump. This increases voltage at your pump based on a boost reference. $150
131183
DW300c 9-307-1000 universal fuel pump. Brand new in box, retails for $189. $125
131185
Discussion Starter · #2 · (Edited)
Upgraded fuel system and lines for P80 AWD. Modified sender assembly with a Walbro 450 and 6AN outlet. 6AN fuel line to an Aeromotive FPR which mounts at the firewall. Single 6AN line to Holley in line fuel filter with a modified M4.4 rail with -6AN bung. This should be good for more than 500WHP on E85. I ran a Kenne Bell boost a pump which limited voltage when not under boost to about 11V. This reduced fuel output of the pump and I was able to keep a linear fuel pressure at idle by running 4 bar base fuel pressure. Without this device you would probably want to upgrade the return line size and outlet into the tank, but I'm not 100% sure that would be necessary. $500
1000cc Deatschwerks injectors sold separately. $300
130911
130912
130913
130914
130915
130916
130917
Custom front bumper made by Hussein. It wasn't done very well so the bondo is cracking. It is repairable, but would take some work to get it right. Comes with fogs. $75.
OG IPD mesh grille. One of the last ones ever made. Basically perfect condition $100
Headlights are sold.
131197
131187
131188
131189
Poly firewall mount for upper engine brace/mount. $12.50
Poly round upper mount. $8
Front delrin subframe bushing, fits P80 and P2 front subframes. $75
Manual throttle cable, an often overlooked part of manual swaps. This gives you better control of the throttle, since it is a longer cable. Volvo PN 9157600 $35
131553
Discussion Starter · #5 · (Edited)
P2 wagon rear spoiler, repainted black. Spoiler was painted and in perfect condition until I dropped it and dented the the inner edge. I also sanded the mounting face a bit to test fitment on a P80, but I don't think this will effect anything. I think the damage from the drop would be easy to fix and probably minimally visible when mounted. $75.
130935
130936
130937
Hubcentric 43.1mm 15 and 25mm spacers with lug conversion and aluminum lug nuts. Lugs are M12x1.5 and nuts are genuine Greddy. On one of the spacers the mounting holes were enlarged, so the mounting bolts are not a totally snug fit. I don't think this matters as I ran them this way for 10,000 miles and never noted any problems. $75
130938
Full size spare for S60R/V70R. Never used tire. $50
130939
130940
How are the bushings in the custom shifter? I have an OEM one that has slop it in and it drives me up a wall. When it's in gear, you can move the shifter left/right.
Got the rear spoiler for the P80, and it arrived with no damage in two days (y). I should have bought the one with the brackets (I have the brackets to the spoiler but not the lower parts). Was going to have the old job fab the lowers for me.
1 - 15 of 15 Posts
