i know the hub ring inside diameter i need is 63.4mm, and my wheel has a 67mm centerbore...what is the the chances of a plastic 63.4mm-67.1mm hubring working??
Re: hubcentric ring size question.... (pcrage_2)
most aftermarket wheels/rims have plastic hub ring so my Rial Como, i think you will have no problem.
Re: hubcentric ring size question.... (xequtor)
i guess my question is what are the chances of getting a 67.1mm plastic hubring to fit inside a 67mm center bore on the wheel??
If its plastic, couldn't you just sand it down a bit if it doesn't fit? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0">
I bought some rings from this guy before, and they work fine. <p>63.4mm ID / 67.1mm OD<br><A HREF="http://cgi.ebay.com/ebaymotors/HUB-CENTRIC-RING-RINGS-SPACERS-OD-67-1mm-ID-63-4mm_W0QQcmdZViewItemQQcategoryZ42614QQihZ022QQitemZ350191546530QQrdZ1QQsspagenameZWDVW" TARGET="_blank">http://cgi.ebay.com/ebaymotors...ZWDVW</A><p><br>Mine are 63.4mm ID / 73mm OD:<br><IMG SRC="http://farm4.static.flickr.com/3370/3198994940_e927187faf.jpg?v=0" BORDER="0">
