1 - 11 of 11 Posts
Hey all!
I was doing this procedure yesterday:
CLICKY HERE
And was driving around and it was fine. Today however, HU850 along with my iMiV went out 10 mins after pulling out of the garage, completely no power and unoperable. This was intermittent. It would come on, then off, then on again every 5 mins.
Could this be a damaged fuse?
If the fuse is broken then it wont power on at all. It may be a damaged wire that has a faulty connection.
I was back in the garage tinkering earlier this evening, and yep, it wasn't a fuse (I tried putting in new ones, same problem). And then I took apart the steering column again, and made sure wires come in contact at every connection again. Problem is still showing, will report back again once I can accurately figure out where the problem is coming from..
This is a dumb question but I am good at those.....Do you have a vlotage meter?
A billion points to test, but can't tell where the problem is coming from.
Where is the amp? I notice that when this problem happens, my dash goes out along with the passenger seat power and my factory Bluetooth kit.
So I completely disconnected the iMiV unit, and problem is still showing. So I ruled that one out.
I think at the same time a loose wire is being ruled out because this problem occurs at set time intervals... Looks to me like something relating to the power driving my passenger seat, factory Bluetooth and HU850 is shorting every 5mins.
No one else has this problem of radio cutting on and off?
Today I tried leaving the battery disconnected for 2 hours. Still not fixed. Could it be a bad radio or amp?
FIXED IT. My iPod was plugged in, left in the driver seat pocket. I inspected it and the connector was a little wet from the Lexol overspray, causing the circuit to short and shut the audio, bluetooth and passenger seat down. Heh.
1 - 11 of 11 Posts
