Post this as a formal question here, copied from another sub-forum:
FusionRedXC60:
Do you know if this could somehow send multiple address to Sensus?
08-15-2020, 09:41 PM #82
WhoaVolvo
VOC / Connectivity Expert
You can send more than one... Out of the box.
08-16-2020, 01:36 AM #83
FusionRedXC60
tried and only the last one shows up in Sensus nav library received list.
08-16-2020, 09:53 AM #84
Gary-16-Xc90
I confirmed @FusionRedSC90 conclusion above with my MY16.
In my multiple sequential tests, the last destination sent (in a series of sending multiple destinations) is retained. In the same setting, I sent Golden Gate Arches (St. Louis, MO) where VOC app confirmed that destination was received; and then I sent Arrowhead Stadium (KCMO) where VOC app confirmed that the destination was also received.
When I went to the car, turned on ignition to Mode 1, only Arrowhead Stadium was received in Library. Golden Gate Archway was not present in the Library.
If I sent the first one and turn on the ignition, the first one is received and retained. If I shut the car off, and send the second one, the second one is also received and retained.
Interestingly and as an aside, if the car's ignition is in Mode 1 (on, not started), the VOC app times out after a couple minutes with a message in red saying "Could not contact your Volvo).
For the short-term, it seems one needs to set up the itinerary while in the car. Hopefully, this limitation and/or sending multiple destinations and having the Volvo retain those multiple destinations (rather than just the last one) can be resolved. Could it be a Volvo USA implementation issue?
FusionRedXC60:
WhoaVolvo
FusionRedXC60
Gary-16-Xc90
