i noticed while dynamatting my trunk lid that there are actually two parts to the trunk lid, and it's that second part that causes most of the rattling with subwoofers -- how do you remove that 2nd piece of the trunk?<p><br>if you dont quite understand what i'm trying to say...<br><IMG SRC="http://memimage.cardomain.net/member_images/11/web/503000-503999/503996_36_full.jpg" BORDER="0"><p>where the seam on the trunk lid is, it separates...
Re: how to remove the other section of the trunk? (Cicada)
You mean you want to remove the cover? The entire rear side of the trunk lid is a plastic snap on piece, held in place by several plastic fastners (10 or so).<p>If you get rid of your license plate cover instead and line the back of the license plate with two layers of dynamat I bet your rattle will vanish.<p>I have a 12" Boston Competition Sub in my trunk with one layer of B-quiet (same stuff as dynamat) and absolutely no rattle at all.<BR><BR>
<i>Modified by ss60 at 1:04 PM 6-27-2006</i>
Re: how to remove the other section of the trunk? (ss60)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>ss60</b> »</i></TD></TR><TR><TD CLASS="quote">You mean you want to remove the cover? The entire rear side of the trunk lid is a plastic snap on peice, held in place by several plastic fastners (10 or so).<p>If you get rid of your license plate cover instead and line the back of the license plate with two layers of dynamat I bet your rattle will vanish.<p>I have a 12" Boston Competition Sub in my trunk with one layer of B-quiet (same stuff as dynamat) and absolutely no rattle at all.</TD></TR></TABLE><p>just checked and you're right; how do i access/release off of these with minimal damage?<p>ill try matting the back of the license plate today and see how that goes. I've got a couple wedge paks lying around from when i wanted to do the trunk lid, but never got around to it, so i'll more than likely do the trunk lid and license plate today -- right now i have two 12" JL W7's in a ported box, so i kinda need as much damping as i can get <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0">
I don't know how they release at the top, but the bottom ones have a notch which slides sideways (parallel to the bumper just under the bottom edge of the plastic). I released mine by accidentally backing into a brick fence post <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0"> <p>I had rattle before doing the license plate too - it disappeared once plate was covered with damper. note* this was without any liner on the trunk lid, I added liner to the lid later.<br>
i did 3 layers of dynamat extreme on the plate itself, and that helped quite a bit, but i think im gonna need to eventually do the whole trunk, trunk lid, and the trunk lid cover to eliminate almost all the rattling... :|
