If it's like most emblems that have a piece of double sided adhesive (tape or foam), then it should be easy to remove. With a long piece of fishing line or dental floss, hold one end in each hand and run it back and forth under the emblem to "saw" through the adhesive. To remove the remaining adhesive, most people recommend WD-40 because it won't harm the paint. I use 3M Adhesive Remover, but I don't think it's safe for clear coated paint. Once you get the adhesive off, clean up the area where the emblem was and use some polish or wax and all signs that an emblem was there should be gone.<P>
