1 - 8 of 8 Posts
Encouraged by the fact that she as good compression, I'm ready to start digging into getting her wiring sorted out.
She has her original ignition switch, compete with the armored cable still attached, but the cable has been cut and wiring hacked in to allow a non-stock coil to be used.
I got up under the dash yesterday but couldn't see a clear way to remove the switch. Any ideas? It isn't cover in the Haynes manual (I did check before asking).
Thanks!
Re: How to remove original ignition switch & armored cable? (tdskip)
There's a little button on the switch body, immediately behind the dash at about the 10 o'clock position. Turn the key to the RUN position and push in the button (it can be quite stiff). That releases the tumbler and the chrome bezel along with it.
Re: How to remove original ignition switch & armored cable? (Phil Singher)
Hi guys - I don't have the key and I tried a screw driver without any luck. So I think I'm stuck doing the the hard way (what ever that is).
Thanks
Modified by tdskip at 1:26 PM 3-21-2009
Quote, originally posted by tdskip »
Thanks George - those look like rivets. Yes/no?
Should I plan on drilling them out?
Those are screws that hold the lock and cable assembly rigid to the dash.
If you take them out you maybe able to turn the lock assembly and see the pin that has to be depressed to remove the lock cylinder. You may then be able to figure out how to get it apart.
1 - 8 of 8 Posts
