So despite having disassembled 3/4 of this car over the years, I've never had to pull the center vents out.
Stuck a couple car trim removers in behind the top and bottom but it does not seem to pop out. How do you get that sucker out of there?
It's the piece with the two vents and the emergency triangle button.
It is unusually hard to pull it from there - and then without braking it. If I remember it has a ton of clips all around, not possible to depress them all at once. Plus, the knob adjusting mechanism is one kind of a fragile and hard to put back thing. Really one of those things you'd want to try first at a junkyard. I talk a little about these knobs here, for the side vent, gives an idea how tricky it is https://www.youtube.com/watch?v=CMN-J4vpphQ
