How to: Oil Pressure Gauge
22K views 14 replies 8 participants last post by  MvI_S60R
I did something similar when I built the new engine although it all pipes directly into the block...more or less what the OP shows above minus the braided line. Works well and neat/tidy. Only issue I had was the crush seal was not sealing when I first fired it up... turns out that the sensor was bottoming out in the fitting before crushing the seal. Simple solution was to double up the seals so they crush before it bottoms out.
I get the moment arm concern btw, but I don't really see it as a problem. Mine's been running strong w/o issue for over a year.
^says the guy with too much time, resource and skill on his hands... ;)
