Re: How to instal MBC (skippy)
From my understanding, you will not be able to use a boost controller. The wastegate is controlled electronically by the ECU. The ECU will attempt to override the MBC -- causing boost spike and fade. <p>The preferred method is to purchase a re-programmed ECU such as...<br><A HREF="http://www.ipdusa.com" TARGET="_blank">http://www.ipdusa.com</A><br>
