After having my plastic accordion piece break and jamming my sunroof, it was time to replace it.
Step 1.
Go to the dealer and get a replacement.
Step 2.
locate the broken piece and remove it. It is simply clipped into the aluminium rail where it slides forwards / backwards with the sunroof.
New replacement accordion:
Step 3.
With the sunroof closed but raised at the rear, remove the remaining accordion piece by simply pulling towards you. You will notice 3 brass clips holding it in place. You do not need to remove these clips.
The broken piece:
Step 4.
Slide the new accordion piece into place and press the front down into the aluminium rail unto you feel it click into place. With your fingers, push down and slide in a motion to completely tuck the new piece into the rail. In the picture - slide from the back to the front.
Step 5.
Grap the top of the accordion and simply tuck it back up and over the three brass clips and push back into place until you feel it lock in.
Step 6.
Test sunroof function and you're done.
Step 1.
Step 2.
Step 3.
The broken piece:
Step 4.
Step 5.
Step 6.
