Hello,
How do you check the engine compression on a 99 Volvo S70 n/a? I have a separate coil on each spark plug. I understand to disable the fuel I remove the fuel pump relay and disconnect each injector. How do I disable the ignition system?
Thanks
Same as any other car. Remove the coilpacks, remove the spark plugs, crank the engine. If you're uplugging the injectors you don't need to turn off the fuel pump.
