1 - 1 of 1 Posts
I put a tutorial on my Instagram here in case these pics vanish
130542
Insert a flat screwdriver into the hole and push on the first tab tab
130543
The light assembly will hinge out on the second tab at the opposite end of the assembly. Now it's out
130544
Twist the light socket from the assembly
Replace the spade type bulb
130545
Reassemble by hooking the second tab "hinge" into its slot, then swing the light back into place and listen for the click of the first tab snapping back into place.
130546
That's it, you're done!
1 - 1 of 1 Posts
