Has anyone changed a rear wheel bearing or have access to a shop manual? I looked for it in Alldata but they did not have the procedure. My right rear is noisy and I should get to it before my wheel falls off. It makes a loud hum especially on left turns (load put on right wheels). Thanks for your help.
Re: How to change rear wheel bearing? (Norbert)
Your warranty may cover it: ask your dealer.
Hopefully, you will be able to have the dealer cover your wheel bearing issue. This is a ongoing problem with the XC90. Volvo should pony-up the bill even if your warranty has expired.
Good Luck.. As you can see from the posts, the wheel bearing issue is not isolated.
