1 - 6 of 6 Posts
· Registered
For new pads and rotors all the way around? This is just parts mind you, I want to see what kind of price I am looking at for the volvo OEM parts since I need to do a brake job here soon.
Also does anyone have the prices on HIGH quality aftermarket pads and rotors, I stress high quality, because I am looking for brakes that will preform as good, or better than the OEM ones.
Thanks,
Kevin
· Registered
Re: How much should I pay? (n00bkiller944)
FCPGroton has a 4 disc 4 pad setup, Brembo rotors and Akebono pads for 355 bucks, I had this setup installed on my wifes' v-70 and it is very close to the oem setup, but virtually dust free! Free shipping from FCP, you'll only have to know if you have 11 or 12 inch front rotors, mine was 11 inch because the car came with 15 inch wheels, I believe if your car came standard with 16 inch or larger you have the 12 inch rotors. I have been very satisfied with this combo, especially the complete lack of brake dust, her car is white and the lower panels would actually turn black with brakes dust inside of two weeks, not to mention the wheels!!!Good luck JHW
· Registered
Upgrade to the R stuff
Rotors and pad and calipers
· Registered
Re: (Chilled Man)
Quote, originally posted by Chilled Man »
That will run just a tad more than the $355 quoted above!
· Registered
Re: (VTT5)
Quote, originally posted by VTT5 »
well he wanted upgraded
$550 per front R rotor
$300 per Rear R rotor
$100 per rotor front and rear
$50 per set of pads ?
So ....
$2400 ish
· Registered
Yeah, I just ended up paying 400 for OEM rotors and pads all the way around, and just finished installing them today!
Thanks for all your help guys! I think i might go with the brembo/akebono next time
1 - 6 of 6 Posts
