· Registered
I have a 2001 S60 2.4T with 72000 miles.
Today, I had an oil change and after letting the car sit for a while I checked the dip stick. I noticed the oil was over the line by about 1/8 of an inch, maybe a little more. Do I need to have some of the oil drained to to the dip stick line?
Thanks.
· Registered
Click on Projects ! @ Website Link !
Re: How much oil is too much oil? (soldonvolvo)
I would , but that's Me .
Under Running Conditions - it will lower , but - I won't be Revving It way Up.
· Registered
usually plus or minus one liter is ok for most cars.
If you are racing and want to keep your engine a long time we add an extra half liter to keep it oiled in the corners . If you want it to go faster in the straights we keep it half a liter low away from the crank shaft.
Or if you have the money dry sump system solves both problems.
