1 - 6 of 6 Posts
I have a 1995 850 turbo sedan with 117,000 miles <br>on it. When I bought it, my mechanic said that the<br>turbocharger is $1800 (USD) to replace, and that it<br>lasts 120,000 miles.<p>So is my turbocharger about to die? and if it does should I<br>get a Volvo turbo or an aftermarket turbo?
Re: How long do turbochargers last, and what is best replacement (e1618978)
Don't know how long there suppost to last but i had to replace mine at 93,000 mile at a cost of $1400. <IMG NAME="icon" SRC="http://********************/smile/emsad.gif" BORDER="0">
Re: How long do turbochargers last, and what is best replacement (doublej95)
I wonder if there is really a magic number, probably goes when it goes. A turbo timer would lengthen the life of the turbo substantially when you get you new one.
<BLOCKQUOTE>quote:<HR>When I bought it, my mechanic said that the<br>turbocharger is $1800 (USD) to replace, and that it<br>lasts 120,000 miles.<p><HR></BLOCKQUOTE><p>Wow..your mechanic must be a "genius"!<p>I have seen MANY (too many to even count) Volvos whose odomtere read more than 200,000 miles and they had the original turbocharger.<p>Make sure that you change your oil when recommended! And using synthetic can buy you extra mileage.<p>Yannis
Re: How long do turbochargers last, and what is best replacement (GrecianVolvo)
When turbo's die it's before 5K miles or else, depending on usage of course, mostly after ~100K-140K miles.<br>Most symptoms are cracked turbine housings.<br>Some turbo's are being replaced while only the wastegate actuator went bad.<br>A new OEM turbo for a T5 shouldn't be more expensive than ~$800 with return of the old turbo.<br>With "normal" daily usage there is no need for a turbo timer.<p>My 850's stock 15G turbo was replaced at 265K km (165K m) but I don't know for what reason.<br>The car is an ex police car with a lot of highway mileage.<BR><BR>
[Modified by Johann, 11:43 AM 1-21-2003]
Re: How long do turbochargers last, and what is best replacement (Johann)
My moms turbo wagon was driven pretty hard and had 184k miles. It was probably close to needing a new turbo. Just make sure the oil is changed at the proper time and you will be okay. Its every 3k miles with turbo engines and like every 5k with n/a engines. For volvo's at least.
1 - 6 of 6 Posts
