1 - 20 of 26 Posts
Re: Horn relocation (p0cket penguins)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>p0cket penguins</b> »</i></TD></TR><TR><TD CLASS="quote">if you moved the horns from infront of the IC would it help with cooling the compressed IC air????</TD></TR></TABLE><br>Theoretically yes, rationally no (because the horns do not obstruct enough of the IC to matter much)
Re: Horn relocation (bschurr)
if you are considering relocating the horn, you might want to consider replacing it too!<p><A HREF="http://www.hornblasters.com" TARGET="_blank">http://www.hornblasters.com</A>/
most of their videos had me laughing pretty hard<p>you can google "hornblasters" at video.google.com and find even more. <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
UGH! I hate those guys.....<p>Ya i removed both my horns, since I use my siren's air horn. Anyone know how to wire the steering wheel to activate the airhorn?
Re: (Copeland)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Copeland</b> »</i></TD></TR><TR><TD CLASS="quote">Anyone know how to wire the steering wheel to activate the airhorn?</TD></TR></TABLE><p>uh huh...take the two leads that go to your factory horn...and run them to your aux. horn.
No! really?!?! jk I guess I should've been a little more detailed in my question. How would one go about finding the leads and splicing the leads without removal of steering wheel/airbag and all those other problems....
Re: (Copeland)
come on man...reverse engineering.<br>start at the horn itself and work backwards...up to the fuse panel (maybe?)<p>no need to open up the steering wheel.
unlike some other people <cough> matt <cough> my occupation isnt "Controls Engineer" I had a hard enough time with the aftermarket stereo, lights, and sirens! <p>Well I am going to start tracking down the wire now....this should be interesting~
Re: (Copeland)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Copeland</b> »</i></TD></TR><TR><TD CLASS="quote">unlike some other people <cough> matt <cough> my occupation isnt "Controls Engineer" I had a hard enough time with the aftermarket stereo, lights, and sirens! <p>Well I am going to start tracking down the wire now....this should be interesting~</TD></TR></TABLE><p>Find the stock horn(s). Remove the leads, connect to your siren. Voila.
Re: (needsdecaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>needsdecaf</b> »</i></TD></TR><TR><TD CLASS="quote">Find the stock horn(s). Remove the leads, connect to your siren. Voila.</TD></TR></TABLE><p>i was going to say: "see cope, it doesn't take an engineer to figure this out"<p>until i looked at needsdecaf's profile:<p>Occupation: Engineer<p>Cheers my friend! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/embeer.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/embeer.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/embeer.gif" BORDER="0">
I need to get a life..... swedespeed and myspace m-f 10-6... maybe I should do my work more <IMG NAME="icon" SRC="http://www.vwvortex.com/zeroforum_graphics/screwy.gif" BORDER="0">
ok.... so according to 'yall I take this <IMG SRC="http://i82.photobucket.com/albums/j267/GhawiJ/hornwire.jpg" BORDER="0"><br>and then I splice it to my switch for the airhorn <IMG SRC="http://i82.photobucket.com/albums/j267/GhawiJ/Photo_051506_003.jpg" BORDER="0"><br>which will then allow the momentary switch inside the steering wheel to push the sound through this<IMG SRC="http://i82.photobucket.com/albums/j267/GhawiJ/Photo_051506_005.jpg" BORDER="0"><p><br>correct?
now you're on track, my young padewon...
Re: (Copeland)
Nope, take the plug that's in your fingers, if that's the one you removed from the factory horn, and plug it direct to your air horn. You may have to add some wire to reach where you mounted the air horn, red will likely be positive. Once hooked to your air horn the center of the steering wheel will activate it. I believe there is already a relay in the horn system so no need to add one. You won't need a second switch on the dash, just one should do.
Re: (vintagemilano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>vintagemilano</b> »</i></TD></TR><TR><TD CLASS="quote">Nope, take the plug that's in your fingers, if that's the one you removed from the factory horn, and plug it direct to your air horn. You may have to add some wire to reach where you mounted the air horn, red will likely be positive. Once hooked to your air horn the center of the steering wheel will activate it. I believe there is already a relay in the horn system so no need to add one. You won't need a second switch on the dash, just one should do.</TD></TR></TABLE><p>yup...we just established that...but thanks for the reinforcement! <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
err wrong people....<p>My airhorn is part of the siren...its an electronic airhorn that is part of my sirens amplifier which includes the wail, yelp, hi-low (eruo tones), and air horn.....its still going to be easy to do after sitting down and thinking about it.
1 - 20 of 26 Posts
