My ('82 244) hood release (inside the car) has always been a bit 'sticky', but it has taken a turn for the worse.
I need to pull extra hard for it to release the hood, and still, it sticks in the "pulled out" position. I must manually push the release lever back in, to disengage it and be able to close the hood.
I can see where this plastic lever seems to enter a "tube-of-sorts" as it enters the firewall, but I don't know if there is anything I can do to fix the problem. I tried spraying some WD40 into the opening, with possibly some results, but the problem persists.
My fear is that I will some day pull that lever too hard and break it, rendering the hood locked shut.
Any help would be appreciated, GREATLY.
