Simple issue that just noticed. On the fob the light button had illuminated the homesafe lighting (or something similar). I almost never use this, so I am not sure if these are the same as the homesafe lights or not.
However, on Friday, I did try to use the fob to trigger those lights, however nothing happened.
Any ideas?
Any ideas?
Have you looked into My Car and seen if the setting was disabled for some reason? I actually had that happen very recently (a week or two ago). I am assuming doing some CEM changes through VDASH was the culprit. I just reset the setting back on and for 60 seconds and all works fine again.
Exactly the issue. Must have been the CEM changes, I forgot that that was even an adjustable setting in the menus.
