1 - 20 of 20 Posts
The dealer quoted me $350 to install homelink in the S60.
I was wondering what was involved with installing homelink. Is the car prewired so all that needs to be done is swap the sunvisors? Does the dealer have to make any sofware changes to enable it?
Re: Homelink (Itgb)
I totally forgot I have this option, I think it came with my mayday/telematics. It didn't work with my German garage opener here though, they use different frequency range than the U.S. Thanks for reminding me.
Banned
Re: Homelink (Itgb)
Quote, originally posted by Itgb »
euh... all non fabric-options are all more expensiver installed afterwards...Volvo is not the only one...to install just wood afterwards in the bmw X5 you are +1700€ poorer afterwards
dunno what it costed as an option when ordering the car but must have been at least half of it... btw...that dude never called back to order it
Re: Homelink (Itgb)
The visor WHOLESALE is about $275 so I guess about $325 retail and a 1/2 hour labor (minimun charge) to install
Re: Homelink (JRL)
Thanks JRL. I guess I will just deal with the remotes.
Re: Homelink (Itgb)
But these are cool. They even light up.
Re: Homelink ("R" Kelly)
Mr. Kelly,
is there ANYTHING you DON'T have a picture of concerning your R?
PS I need to see more pictures of your Jetex exhaust tips in relation to the back bumper. Directly from the rear, and profile. Please. Feel free to start another thread.
Re: Homelink (pino)
Quote, originally posted by pino »
Mr. Kelly,
Nope... I have over 600 pictures loaded on Image Shack, all of them posted on swedespeed at some point.
And if I don't have one, I can go take a picture and have it posted in under 5 minutes. (as in the case of the homelink, wanted close up).
Homeling visors frequently show up on ebay, usually in pretty good condition. Maybe worth a look? Not sure about the wiring though. I would guess it just plugs in to existing?
Re: (rgrove)
Anyone know how to increase the range of the homelink? Idealy I would like ours to open the door far enough away so that at a slow roll I can go in without stopping. Right now it's about 20ft from the door....
Re: (vintagemilano)
Quote, originally posted by vintagemilano »
Someone pointed out to increase the range of the key fob, hold it perpendicular to your chin, may be a bit awkward with the visor, but probably doable if not highly entertaining for anyone watching.
Re: (vintagemilano)
It may actually be an issue with your opener. I just moved to a new house, and the homelink in both my cars doesn't work for crap...you have to be practically touching the garage door in order to get it to work.
The funny thing is, that I have them coded to my father's house and my grandparents house, and they work from a couple hundred feet away on both openers.
The garage door installer at my new place said that some brands / units just don't work that well with home link. The funny thing is that the unit in my father's is made by the same brand as mine....Lift Master, and mine is the cheaper Access Master model from the same company. Both are rolling code, as well.
Very strange, but proven to be true.
2005 V70R, Midnight Blue, M66
Re: Homelink (Itgb)
The HomeLink unit requires just +12v and ground. Both of these are already in the visor to power the mirror vanity lamps. They are on the same fuse/circuit in cars that are equipped with HomeLink from the factory. There is no software download required other than what you must do as a user when learning rolling codes.
In regard to extending the range, it might be easier to consider extending the range on the receiver, which is on the garage door unit. Make sure there is an antenna wire attached, it is not blocked by metal objects etc.
Discussion Starter · #14 ·
Update
Just as an update, I contacted Erie Volvo since they had a few S70 visors on ebay and sure enough they also had the homelink visor for the S60. The install was really easy(plug & play) and my range is just as good as my garage door opener. The only drawback was that the sunvisor was not cloth like in my '05, but the textured vinyl like on the doors. By reading the molder mark on the plastic clip, it looked like this one was from an '01. So I'm assuming they changed somewhere along the line. So I ended up ordering a matching passenger sunvisor just for the sake of matching.
Oh and the best part...only $125. Not the $300 that the dealer was asking. http://********************/smile/emthup.gif
Re: (vintagemilano)
my range is improved when I pull the visor down slightly as I press the button...maybe it improves line-of-sight, I don't know, but it does make a difference
Re: (kenschel)
My homelink works from at least 100+ feet down the street. It probably depends on the sesitivity of the opener. I have the Genie Screw Drive. Very nice , quiet and opens in about 5 seconds.
-Ben
Re: (bcantana)
Quote, originally posted by bcantana »
-Ben
No, it definitely depends. See my post above. I have a crappy low end builder spec opener and it works like crap with the homelink. On both my cars.
My relatives better models....way down the street.
Re: (vintagemilano)
My Homelink works from about 80 feet away in both cars. I have a pretty clear shot at it from the end of my driveway, which might make the difference and I do depress the button for a good second or so. When I am closer, it doesn't seem to require such a long push of the button to trip the opener. Do you have obstructions between your car and the garage when you are more than 20' away?
I wonder if the performance is affected by how close you are to the opener when you train the Homelink system - I doubt it would, but I find this to be the case when training my programmable infared TV remote. Different signal types, I know. When I trained my Homelink systems, I parked the cars directly under the openers. Might be worthwhile to try reprogramming to see if the performance changes.
- Tryg
Re: (RainyS60R)
Quote, originally posted by RainyS60R »
- Tryg
I have no obstructions and the ONLY way I could get the Homelink to train was in the garage. It would not train outside.
I spoke to the garage door installer and he told me that the lower end, buider spec model that I have has all kinds of problems with the homelinks. Who knows why, it has great range with the transmitter it came with. When I have the garage open for spring cleaning, I am going to splice on a longer antenna wire to see if that helps. I'm betting it will. I might also try running a tail of it outside of the garage and hiding it in the stonework on the front of the house, just to see if that helps as well.
Re: (needsdecaf)
With most wireless "training" it has to be done within a few feet of one another. Great example is when I trained my homelink outside of the garage the range was poor.(30 feet max) When I trained it right under the opener, the range is now almost 2 blocks. http://********************/smile/emthup.gif
1 - 20 of 20 Posts
