1 - 2 of 2 Posts
I put a DrawTite hitch on the S60 for some rare utility trailer use and to also assist jacking up the rear of the car. Anyway, on the passenger side there is a steel bracket with a welded on steel tube. It has to be removed and not put back on to bolt up the hitch. What is the bracket for? Maybe a tie down for chaining down during shipping?
I had the same on my XC70. I believe this is in line with the square plastic part of your bumper which is to be removed should you put your car in a ditch so that it can be towed out. Whomever is pulling your car out will hook up to that bracket/tube.
1 - 2 of 2 Posts
