So the other day my car started making a high pictch whistle sound. It was hard to pin point but sounded like it came from the front of the engine. This is the 2nd time I had this issue. Last time it was the oil breather was messed up. I took it to the dealership on Monday and it was the same thing. The replaced the entire assembly. This is the area where the oil filter is installed in the front of the enigine. Under warrant so no charges. They said that the design has been changed and it shouldn't happen again.
Just thought I would give others the heads up if they have a similar problem.
