1 - 10 of 10 Posts
Is there anyway that you could leave the high beams on with out the fog light cutting off and with out holding the turn signal arm back? Just a question
Re: High beams...... (xUNiQuE)
Quote, originally posted by xUNiQuE »
I'm not sure about the foglights. Try turning your headlight dial to the vertical position. You should be able to click on the brights.
Apparently Volvo designed the DRL's (horizontal position) to act like the "always on" except for highbeams must be held.
Re: High beams...... (Tiny)
Quote, originally posted by Tiny »
it has nothing to do with that.
when you turn the high beams on, the fogs instantly turn off.
Re: High beams...... (Impulse922)
Quote, originally posted by Impulse922 »
I believe it can be programmed but most dealers are reluctant.
Re: (DGBibo)
There is a Euro software available that allows fogs with high beams
Many/most dealers won't sell it to you but if yours will, let me know and I'll get you the Part number
Re: (JRL)
A lot of states have laws that specify no more than 4 headlights can be on at a time (lows + highs + fogs = 6), which is likely why some dealers are reluctant to assist. If you can find one who will hook you up, JRL's your man to get the "inside info."
Re: (JRL)
I work at a volvo dealership. I talked to a tech and he said there is no way.
If you have a part number, i'll take it in to work with me tomorrow and i'll find out
are you saying I'm wrong? your post had nothing to do with what I said. I admitted I didn't know about the fogs, but helped him with the highbeams.
2007 XC70
You're not wrong it just didn't really have anything to do with what the OP is asking. The foglights turn off when high beams engage and he's trying to keep the fogs on at the same time as high beams.
You still trying to put these HID's in?
1 - 10 of 10 Posts
