1 - 11 of 11 Posts
So a semi threw a rock at me and cracked the headlight casing on the passenger side. I snagged a new set of headlights from the forum but not before driving to work in the rain caused "low beam bulb failure" and the light stopped working.
Tonight I put in the new light, got it all back together and.... nothing. The light still doesn't work. I tested on either side and the light I got is good, for some reason my car won't run the light on the passenger side. I checked the fuses and they are all fine, the bulb is fine and the new headlight is fine. I tried disconnecting the battery for a few minutes but it didn't solve it.
Does anyone have any ideas? Does this mean my wiring harness is shot? Do I need Vida to re-initialize the HID on that side after it detected a fault? Does anyone know which prongs to test with a multi-meter to see if the plug going to that headlight is live? I'm open to trying things, I just can't think of anything.
Failed ballast attached to the bottom of the headlamp? Moisture likely leaked from the headlamp down to the ballast.
Options:
1.) dry out the ballast with alcohol. Don't use rubbing alcohol, rather the 90%+ pure stuff.
2.) replace ballast with used one available on eBay for about $100.
3.) replace ballast with new one from stealership for an arm and a leg.
I swapped it with a full new headlight. If I plug it into the drivers side it comes on if I plug it into the passenger side it stays off.
Did you swap the bulb, the ballast, or the entire headlamp assembly?
Here's a video. Start about the 16:30 mark.
Entire headlight assembly. It works plugged into the drivers side, doesn't plugged into the passenger side.
According to this it says when you order a new headlight assembly you need a new wiring harness. Has anyone else experienced this?
Did you check the fuse?
Yeah, as far as I could tell the fuses aren't side-dependent and all the ones I checked were fine.
H
I bought 2 used R headlights to replace the messesd up cracked ones on my 04, and both of them just plugged right in and worked no other BS.
If both lights work on one side and neither do on the other, it's a wiring problem. I'd get out the meter and start testing connectors to find the one that's not working. I've never seen a headlight reset inside VIDA but I've never looked either, it's possible I guess. If you don't have VIDA, try an ECM reset after reconnecting the replacement headlights.
1 - 11 of 11 Posts
