1 - 9 of 9 Posts
Hiya,
Having some problems with my DDM kit - this connector is loose, not sure if its the wire or what...causes the light to intermittently work or flicker while working...it's this connector right here:
any advice on how to replace?
I used to have a " flickering " issue and sometime they wld cut out . turned out it was because volvo use 55w headlights where as 99% of other cars use 35w. This messed up the canbus " bulb out " sensors and made them cut out and or flicker. I tried the canbus cancelors with no effect and eventually just went for 55w HID's. not sure if that helps, or if you just have a loose wire :p
1 - 9 of 9 Posts
