Whats the proper way to install aftermarket HID. How are the Xenon-shop hid's ? What else do they require?<br>Thanks<br>Parvish
Re: HID Help (Wish2k)
Are you going with regular or bi-xenon? If youre going with the bixenons IMHO id rethink it…more trouble/expense than its worth.<p>Most of the aftermarkets ive installed/delt with were pretty simple plug and play. You plug the ignitor/ballast (some use a one piece design – which tend to be better quality even OEM but are sometimes harder to find, and some use a separate ballast and ignitor which have proprietary plugs. These are slightly lower quality, but are usually ok. Keep in mind with this design the bulb connector <not base> will likely be proprietary as well. You wont be able to just order some new rebased d2 bulbs <if you burn one out or want a different K rating> without some fab work – you ill have to get them from the same place you got your kit) into the stock harness and then into the new d2(s/r) bulb which has been rebased for your housing. On some kits youll have to add a relay or an additional power wire – but those were largely in an older generation. <br>That said, if youre trying to retro a set its quite doable, but much easier to get a set (like above) that’s designed for the vehicle. <p>-<br>CH <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/embeer.gif" BORDER="0">
Do you know where i can find the combined igniter/balast kits? Like a dependable kit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Wish2k</b> »</i></TD></TR><TR><TD CLASS="quote">Whats the proper way to install aftermarket HID. How are the Xenon-shop hid's ? What else do they require?<br>Thanks<br>Parvish</TD></TR></TABLE><p>You might get better results if you search here (including the archives) and read up on previous owner's experiences and post in a thread that is relevant to what you're looking for.<p>Some people in the past have had issues with HID installation with trouble getting the lights to work with the software in the car... worth reading up on that if you're thinking of going that way.<p>UKMatt
