Fellow SS volvoists,
My car has been winking for the last few weeks and I’m not sure which part is a culprit. As I don’t have a garage to work on it, I was hoping I could use few pointers. It’s rather cold again, to work on a car outside.
Cheers and thanks in advance!
Sounds like you may have a failing ballast.
Start with the low hanging fruit. The bulbs. Swap them from side to side. If the blinking follows, there's your answer. If not then your ballast or igniter are the next step to swap from side to side. If the problem persists then you are most likely looking at a harness issue.
Its probably the bulbs. I had the same issue and after swapping ballasts back and forth, finally bit the bullet and got new bulbs. Good as new
