1 - 20 of 25 Posts
Well tomorrow morning I take my car in for the 3rd time to get this and the automatic wipers fixed (also 3rd time).<p>Does anyone else have a similiar situation?<p>Of course they are not related, but has anyone else suffered from this?
how bad is it? no boost at all, or does it take a long time to spool.<p>if it takes a long time to spool, or doesn't quite get up there...check for boost leaks...maybe a loose vacuum line.
Re: (phuz)
Somebody needs to state the obvious:<p>Get a boost control solenoid and replace it yourself if they "can't reproduce the problem" or fix it this time. <p>At worst you blew $50 and now have a spare for when it does go bad. Trust me it will.<p>At best you will have found and fixed the problem yourself and possibly saved yourself a dealer trip. <p>That was worth $50 for me and it did miracles. I had to re-learn to drive the car, shifts were too smooth and it moved the powerband sweetspot around in each gear.
Re: (MMIV R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>MMIV R</b> »</i></TD></TR><TR><TD CLASS="quote">better word - "bogging"</TD></TR></TABLE><p>Have they changed the boost control solenoid?
Re: (MMIV R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>MMIV R</b> »</i></TD></TR><TR><TD CLASS="quote">better word - "bogging"</TD></TR></TABLE><p>Yes "bogging". Feels like you're pushing through a wall in the low RPMs in every gear. And then boost comes on all at once after you punch through about 3-3.5k. Not linear at all and a royal PITA to drive.<p>This is not the launch bog necessarily, although a bad BCS will make that horrendously worse too.
Re: (MMIV R)
You did get the Volve ECU patch for the '04s way back when, right? <p>If not I'm sure they would have caught this on a previous visit given your symptoms... But it's worth asking about if you're not sure.
Re: (needsdecaf)
changed the solenoid 7k miles ago<br>replaced fuel pump 14k miles ago<br>replaced fuel pump 14.2 miles ago<p><br>ecm upgrade 17k miles ago<p>
Re: (StaggRLee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>StaggRLee</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Yes "bogging". Feels like you're pushing through a wall in the low RPMs in every gear. And then boost comes on all at once after you punch through about 3-3.5k. Not linear at all and a royal PITA to drive.<p>This is not the launch bog necessarily, although a bad BCS will make that horrendously worse too.</TD></TR></TABLE><p>Ummm, that is how the R turbo drives! That is how mine has been (especially in the summer heat) since I bought it!<p>
Re: (cschmelz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>cschmelz</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Ummm, that is how the R turbo drives! That is how mine has been (especially in the summer heat) since I bought it!<p></TD></TR></TABLE><p>Yes but when my BCS was going, it slowly got worse and worse - so slowly that I didn't notice it happening. Doesn't sound like that is MMIV's problem though unless he had the replacement fail in 7k miles.
Re: (cschmelz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>cschmelz</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Ummm, that is how the R turbo drives! That is how mine has been (especially in the summer heat) since I bought it!<p></TD></TR></TABLE><p>Not mine. There is definitely some lag, but it's not obnoxious. And I'm making good power well before 3,000 RPM. Closer to 2,000 to 2,500 is when it surges in.
You could install titanium blades and port/polish the turbo and manifolds. This will definitely help reduce lag/hesitation. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
Re: (needsdecaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>needsdecaf</b> »</i></TD></TR><TR><TD CLASS="quote">Not mine. There is definitely some lag, but it's not obnoxious. And I'm making good power well before 3,000 RPM. Closer to 2,000 to 2,500 is when it surges in. </TD></TR></TABLE><br>Although most of us on this board knew what we got into when we bought a high pressure turbo engine, it is not universally true.<p>The behavior you describe is unacceptable to some people. This is why turbocharged engines are relatively rare. The dealer can only tell the customer "they all do that", which is a very unsatisfying response to a PO'd buyer.<p>This may be the case here.
Re: (Dyno)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Dyno</b> »</i></TD></TR><TR><TD CLASS="quote"><br>Although most of us on this board knew what we got into when we bought a high pressure turbo engine, it is not universally true.<p>The behavior you describe is unacceptable to some people. This is why turbocharged engines are relatively rare. The dealer can only tell the customer "they all do that", which is a very unsatisfying response to a PO'd buyer.<p>This may be the case here.</TD></TR></TABLE><p>a good salesperson would have addressed this beforehand.<p>Also.... anyone ever hear of a test drive
Discussion Starter · #16 ·
Re: (R_Rated)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>R_Rated</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Also.... anyone ever hear of a test drive</TD></TR></TABLE><p>I have owned this car for 3+ years, I think I know how it should be driving. <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0">
Re: (MMIV R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>MMIV R</b> »</i></TD></TR><TR><TD CLASS="quote"><p>I have owned this car for 3+ years, I think I know how it should be driving. <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0"> </TD></TR></TABLE><p>I don't think that comment was directed toward you, but toward the "none of them come on before 3,000 RPM" comment. <p>I have driven maybe 5-6 R's and not one of them had bad lag up to 3,000 RPM or I would have never purchased the car. I've driven several cars with HPT that had far worse lag / power on situations than the R (Daytona, Talon / Eclipse)
if somneone is having a problem with boost..would installation of ab oost gauge give them a way to diagnose this? you would see boost PSI be too low at certain rpms...???
Discussion Starter · #19 ·
Re: (23109VC)
UPDATE -<p>Picked up car earlier tonight from dealer - on work order:<p>"Hook up VST read and fault trace code ECM 000B - found misfire cylinders 5&4 - replace faulty ignition coils - test - no further fault present."<p>Drive home ... 'she felt like she's straight off the boat' <p>My car hasn't driven this good in a long time! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> <p>*** word to the wise ... I got the service manager involved ***<p>ps. The rattle in the dash was fixed as well as the rain sensor wipers now work correctly.
Re: (MMIV R)
Glad to hear it is now resolved. Kudo's to the tech that finally took the initiative to fix the guys car who ultimately pays his salary!<p>If only there was the initiative to do this on first trip, a classroom plug and play diagnostic and repair, and without intervention from the service manager. <p>I do not recall other cases of failed coils on these cars, at least mentioned on this board.
1 - 20 of 25 Posts
