1 - 6 of 6 Posts
Car is in limp mode scaned the codes and the scaner says problem with gas pedal <br>my friend has the same car as me <br>swaped pedals and same problem .<br>What to try next got 2 cars with me<br>thanks so much
Re: Help with problem reduced engine performance (ertech)
Throttle <B>position sensor </B>is probably what it meant
We just found the problem. The ac clutch fuse is the culpid<br>on my 04 the fuse sticker only says ac clutch <br>on the 07 it says ac clutch and accelerator pedal .go figure<br>thanks<br>
04 vs 05+ are completely different electrical systems
Like s140s said, completely different electrical systems. If that fuse fixed your problem i'd now be concerned as to why the fuse popped. They don't just blow unless there's a fault somewhere.
1 - 6 of 6 Posts
