My wife's 2005 S60R passenger-side bumper cover has been pulled off too many times by getting hooked on a parking block. I finally bolted the bumper to itself under the license plate so it will not come off short of ripping the engine block with it!
Anyways.. one of the causalities of the bumper cover coming off is the passenger fog light falling out and shattering on the ground. I replaced the fog light without removing the fragile bumper cover (PITA), but there is no power in the wiring harness. I checked the fuse and it is still good, so there must be a broken connection somewhere between the fuse box and the fog light wire harness.
Can anyone direct me to a wiring diagram of where the wires go from the fog light? I can't even see what happens after they go up next to the washer reservoir. (I tried getting the reservoir out so I could see better but I couldn't figure out how to get it out after losing the bolt on the bottom.)
I'm guessing the wires got pulled when the bumper cover came off and are broken/disconnected somewhere on the passenger side.
Any help would be appreciated!
