1 - 6 of 6 Posts
I have changed my coolant and after a year I noticed that i have a missing panel under my car. I dont know if it fell off or if a dealer removed it during an oil change. Since I cant detect how it happened I am interested in getting a new one. The purpose of this post though is to ask how to take it out and put it back in. The reason is that when i removed the panel in the past I was changing the coolant. During the time i change the coolant removing the panel I broke a tab on one side. So when I put it back in or remove it again I want to make sure I dont break the tab again. I hope this makes sense?
Can't picture what panel you are referring to. Is it the piece that fills the gap between the front bumper cover and the under engine cover ?
Search for 31386719 and/or 31323860.
31386719 is held to 31323860 by clips (30763619).
Hope this help.
31386719 does not use any clips.
It also does not come off for an oil change. So if that is the panel you are talking about, it wasn't left off after an oil change.
30763619 is shown linked to 31386719 in the parts diagram. Any ideas what this clip is for ?
31423860 uses those clips. But 31386719 does not. 31386719 is likely the panel he removed to drain the coolant. Sounds like he damaged one of the tabs that holds it in place and therefore it fell off.
Hope this help.
Yes, that is the part ===> "Is it the piece that fills the gap between the front bumper cover and the under engine cover ?"
1 - 6 of 6 Posts
