1 - 10 of 10 Posts
04 Volvo S60 R m66 oe body kit. IPD Downpipe, Catback, HD TCV, Boost Gauge, HD End Links, Poly Sub
My laptop keyboard stopped working I can't access the EWD. Can someone tell me what this goes to on the 07 s60R m66 it showing 13 volts and my active chassis is getting no power to the SUM. Also breaks worked fine replaced radiator condenser and inner cooler all of a sudythis stupid snow symbol that doesn't resist on the 04 popped on now it's in some kinda snow mode so I have to step extremly hard on the breaks. First is of plug second of stupid snow thingy
Automotive tire Light Motor vehicle Black Automotive wheel system
this is drivers side next to air intake under weird plastic cover
Motor vehicle Hood Automotive design Automotive exterior Automotive tire
Automotive tire Motor vehicle Automotive design Tire Bumper
I'm hoping this is my issue I ran atoner and it tracks threw the suspension and only pics up under rear wheel wells
Here's my breaking issue light, don't know where this sensor is or how to get this to quit…
Automotive lighting Amber Triangle Font Gas
I also can't use vida cuz no keyboard even though it's a touch screen the touch won't work in a vm go figure
this is drivers side next to air intake under weird plastic cover View attachment 134770
You don't have a usb keyboard laying around?
That "snow symbol" is the ABS warning light. That's the Anti-lock Brake System.
This is the connector for the Auxiliary Light harness, so you can run external lights that come one with the high beams, ignore it and continue on. Pretty neat that Volvo implemented it into the cars from factory, I made use of it.
Sent from my Pixel 3a XL using Tapatalk
Ok that's dope !! Learn something new everyday
How does that make any sense when there is literally an abs light right next to it. Ok thank you I'll start with the pump I suppose maybe it's not building pressure
Maybe it's the traction control warning? I'd check the owner's manual to verify but I drove the Jeep to work today.
The hard breaking is because of that symbol it puts the breaking like this due to icy conditions so you don’t slam on the breaks, it got tripped due to a bad speed sensor drivers side after I removed the bumper. Guess I bumped it to hard or something breaks fixed thanks
1 - 10 of 10 Posts
