1 - 1 of 1 Posts
I have a 2006 s40 2.0D sport and have had this for just over a year. The AC has never worked from buying the car and when I have hooked it up to my Autel D208 all systems I am getting the following code CCM 0001 Configuration fault not accepted value. I have also bought a dice unit and get the same error code. I have full function of the CCM except the AC button does nothing ( I tested the relay with the dice and it works) just not when pressing the AC button. I have also tried 2 other CCM units from the scrap yard and they also are the same everything works except the AC button ( just to be clear the LED light does change over from on and off when pressed ). I have also tried calibrating with the dice but still get the same code as mentioned above. I would appreciate any helpon this as summer is now upon me and I am cooking in the car. Thanks in advance
1 - 1 of 1 Posts
