1 - 11 of 11 Posts
a couple months now i have been having issues with what i keep thinking is boost spiking drives fine until i accelerate hard to WOT and my boost gauge reads ~15psi acts like it has a 2-step (has a stuttering problem) then just falls on its face i changed spark plugs and air filter changed oil but other than that that is it any ideas to as what is going on??!! thanks in advance!
FPS.
just the fuel pressure sensor thats it?
Could be a lot of things. Check for boost leaks also.
Coil, FPS or fuel pump
is there a code that comes up for the fuel pump? or a way to check if it really is the fuel pump
Well it depends, FPS sometimes will not give you code, sometimes the car runs perfect and shut the fuel for a second or two, or worse, shut down your engine in the middle of the highway.
Monitor the fuel pressure on VIDA, if it goes too much over the nominal 480 Kpa, and acts real crazy, you know it is the sensor. You might even diagnose a failed pump with monitoring in VIDA
1 - 11 of 11 Posts
