1 - 20 of 21 Posts
Yea, sooo i spent all morning installing my 55w. 4300k HID kit from SharpHID.com. And well, i turn the car on, and they work fine....but for only 10 seconds. I have 2005 S60 T5, 55w kit, and cancelers. What to dooooo? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0">
Did you not believe me? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0"> I told you battery harness would be necessary.
Re: (shagginwagon)
hahaha ok ok U WERE RIGHT. <B></B> but fyi, dont expect that often lol. Sooo if i get that, how does it all work?<p>Sharphid.com<br> <IMG SRC="http://sharphid.com/images/wiringharness.jpg" BORDER="0">
Don't expect that too often? What are you trying to say <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> <p>HID ballasts get signal to ignite from stock wiring harness but draws actual current from battery using that harness. Connect the harness to the positive terminal at the fuse box under the hood and to one of the three ground terminals on the side of the engine bay. It comes with a schematic for hooking it up to your HID ballast/bulb (in a nutshell, it just gets connected in series between the ballast and bulb for both passenger and driver side). <br>BUT<br>I'm 99.9% sure you won't get that bulb out message to disappear.
Re: (shagginwagon)
OHHHHHH k...that makes since. Seeing as i came from a nissan altima se-r , to my volvo, wich to be honest, ill never get anything else <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0"> but yaaa...is that the setup u have? And about the "dont expect", im stubborn lol.
Re: (shagginwagon)
Yea....ooohhhhkk ill try this...ill keep u posted. <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Re: (Max Wells)
Shaggin knows what he is talking about.... you shouldn't have doubted him<br>I don't know why you made your first thread if you weren't gonna follow anyone's advice <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0">
With the battery kit you're sure to get the headlamp out message. With the kit it's sensing even less current draw / resistance in the circuit. Computer will definitely think the bulbs are burnt out.
It's not really the wattage that matters as much as the pattern in which current is drawn vs time in this case. The CEM can see that the HID's are different than halogens because of the time involved in igniting and warming up the HID bulbs but it can't see that the bulbs aren't out. If somehow the system were to take action 20 seconds later than it does, the current drawn would be stabilized to around 55w which would probably get rid of the bulb out message. In any case, you'll have to live with the error message if you want the aftermarket HID's in our cars (05+ P2)
Re: (Tiny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Tiny</b> »</i></TD></TR><TR><TD CLASS="quote">Shaggin knows what he is talking about.... you shouldn't have doubted him<br>I don't know why you made your first thread if you weren't gonna follow anyone's advice <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> </TD></TR></TABLE><p>yeaaaaaaa i actully listened this time lol.....thanks bro, john still insists that the cancellers that he sent me were bad and he shipped new ones out...so well see, but i do have a relay harness right now and as u said b4..it works amazingly haha...but yea ill keep you posted <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
I have the same problem and John from (sharp HID) is looking into the problem. He gave me the cancelers but they are 50/50 in the daytime. They turn off after 10 seconds or so. He thought there might be something wrong with the batch of cancelers that he just received. You can always go to a volvo shop and get a flash update in your ECU to enable that warning out signal and the signal will be permanently out.
Discussion Starter · #15 ·
Re: (EvolveT5R)
really.....yea thats what happend to me, had cancelers and it was on for 10 seconds and then off.....but well see monday when he sends the new ones...and do u know the code that i should ask for?
Re: (Max Wells)
Jon asked for a picture to see if my cancelers were the wrong kind, but he said he sent the right ones. Let me know if your new sets work.
Re: (EvolveT5R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>EvolveT5R</b> »</i></TD></TR><TR><TD CLASS="quote">I have the same problem and John from (sharp HID) is looking into the problem. He gave me the cancelers but they are 50/50 in the daytime. They turn off after 10 seconds or so. He thought there might be something wrong with the batch of cancelers that he just received. You can always go to a volvo shop and get a flash update in your ECU to enable that warning out signal and the signal will be permanently out.</TD></TR></TABLE><p>Have you actually confirmed that this flash exists? I'm 99% it doesn't.
Discussion Starter · #18 ·
Re: (shagginwagon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>shagginwagon</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Have you actually confirmed that this flash exists? I'm 99% it doesn't.</TD></TR></TABLE><p>The truth is no...I just talked to a buddy of mine who's a true service tech at the Volvo store in Orlando fl where I live and the only software he know pertaining to "hids" is the software that allows the steering control unit to control the active bi-xeono lights availible on the 08+ s60 and other models that have that like the new s40 and 80. Other than that he said it doesn't exist. The oem hids found on the R and such; he sais, the hid balast has a chip in it that works with the cars cem...soo it's basically telling the cars cem that it's an oem part..and it's cool basically. Soo that's what he told me today... <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0">
Discussion Starter · #19 ·
Re: (Tiny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Tiny</b> »</i></TD></TR><TR><TD CLASS="quote">Jon asked for a picture to see if my cancelers were the wrong kind, but he said he sent the right ones. Let me know if your new sets work.</TD></TR></TABLE><p><br>Soooo its ano go...they didnt work....i just think anything 05+ is doomed lol <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0">
1 - 20 of 21 Posts
