1 - 2 of 2 Posts
Hi all,
My XC90 spun a conrod bearing.
In need of a quick cheap fix before I go all out and replace the engine......
There's minor deposits of bearing on the crankshaft, I will try my best to sand it out.
The rod and cap appear not too bad, the bearing is scrubbed and squashed.
I'm looking for a set (two pieces) bearing for the Connecting Rod. Used is perfectly fine - once the top layer isn't worn off.
It's for a 2004 T6 - B6294T but I believe any White block/B series engine will have the same bearings.
Surely someone has done a rebuild and have the old ones lying around?
Any help appreciated!
1 - 2 of 2 Posts
